problem with first printing
Gabik87
(@gabik87)
I have problems on many things.
at the last minute before the end of printing. the piece comes off and I had to finish immediately.
looking at other things, I don't think the quality is perfect. what should i improve? I have the Z axis set to +750.
Before printing I cleaned the top with alcohol and put some lacquer on it. Just the lacquer is enough.
Before this print, I tested the first layer.
The filament comes out after a while and I have to start printing twice.
What should I improve?
What should I do for all problems?
Attachment removed
Publié : 12/09/2019 8:30 am
Lichtjaeger
(@lichtjaeger)
RE: problem with first printing
Your Z calibration is way off please see this.
Publié : 12/09/2019 8:43 am
Gabik87
(@gabik87)
only this problem?
Publié : 12/09/2019 10:54 am
Lichtjaeger
(@lichtjaeger)
It affects all of your other problems.
Publié : 12/09/2019 10:57 am
The bed is very sensitive to skin oil; fingerprints will cause parts to lift and break free.  Alcohol only smears the oils around.  Instead, you need to wash them up and rinse them away using a large volume of liquid.  Soap and water at a sink is the best way to ensure the sheet is clean.
Then only handle the sheet by the edges and don't touch the print surface - it's best to use tools to help remove parts.
Example Layer 1:
Ce message a été modifié il y a 7 years par --
Publié : 12/09/2019 7:06 pm
Gabik87
(@gabik87)
THANKS A LOT FOR YOUR ADVICE.
how did you make such a smooth layer?
Belove, my second print! How I improve it?
Thanks
Publié : 12/09/2019 8:20 pm
