problem with first printing
I have problems on many things.
at the last minute before the end of printing. the piece comes off and I had to finish immediately.
looking at other things, I don't think the quality is perfect. what should i improve? I have the Z axis set to +750.
Before printing I cleaned the top with alcohol and put some lacquer on it. Just the lacquer is enough.
Before this print, I tested the first layer.
The filament comes out after a while and I have to start printing twice.
What should I improve?
What should I do for all problems?
RE: problem with first printing
Your Z calibration is way off please see this.
only this problem?
It affects all of your other problems.
The bed is very sensitive to skin oil; fingerprints will cause parts to lift and break free. Alcohol only smears the oils around. Instead, you need to wash them up and rinse them away using a large volume of liquid. Soap and water at a sink is the best way to ensure the sheet is clean.
Then only handle the sheet by the edges and don't touch the print surface - it's best to use tools to help remove parts.
Example Layer 1:
THANKS A LOT FOR YOUR ADVICE.
how did you make such a smooth layer?
Belove, my second print! How I improve it?
Thanks
