Printing keep clogging and failing
Charles Coonz
(@charles-coonz)
While trying to pring the prusa enclosure version 2 top corner pieces i experience constant failures and bad print quality.  I can get a perfect first layer and after a while i get cloging or bad extrusion and the print starts to break down due to these rundom clogs. I have tried several different adjustments, speed reduction, profiles calibrations end so on but the damn thing keeps doing the same. I have 50 to 45% humidity with a humidifier running, tried different temperatures for my petg and different petg packages from prusament all with themsame results. When i pring this large surface the print progressively breaks down. Can anyone help me out? I am beggining to regret not going with the zortrax cause i seem to spend half of my printing time debugging the damn thing.
Publié : 01/12/2019 7:57 pm
RE: Printing keep clogging and failing
Hi Koutso,
Have you tried reducing the retractions to say 0.4mm?
Publié : 01/12/2019 11:33 pm
Charles Coonz
(@charles-coonz)
After doing some research i found out that this was due to extruder clogging. I did the cold extrusion cleaning method and the problem was resolved.
Publié : 02/12/2019 7:44 am
Good news, regards Joan
Publié : 02/12/2019 4:18 pm
