Printing fails - unknown issue
Kim Jones
(@kim-jones)
I encountered a unknown print fail. The bed got recently leveled. Obviously (to the left) there might be some ringing or Level-height inbalances,, but I can't understand the origin of fail what's going on to the right edge - seems, like the nozzle somewhat tries to peel off the printed layer??
Thanks
Best Answer by JoanTabb:
That looks like fingerprints... causing reduced adhesion!
Regards Joan
Veröffentlicht : 29/11/2023 7:13 pm
RE: Printing fails - unknown issue
Regards Joan
Veröffentlicht : 29/11/2023 7:44 pm
Kim Jones
(@kim-jones)
For real? 😅
Okay.. I righteously wiped the unheated plate with isopropyl - maybe this wasn't as good as to have it cleaned with dishwashing soap? Hm..
Thanks!
Veröffentlicht : 29/11/2023 9:48 pm
IPA can spread finger prints more evenly over a larger area and then evaporate... leaving the grease behind. if you use enough IPA and enough fresh paper towels, you can clean the bed. if you turn the ipa soaked paper towel over and use the other side, you may be transferring fresh grease off your fingers, back onto the  build plate.  suitable gloves may prevent this additional issue.
Dish soap binds the grease to surfactants and the rinsing washes them away...
It works for me.
It costs very little to try...
Wash rinse and dry immediately...I use a new sponge, so I know it is uncontaminated. and I keep it separate specifically for cleaning build plates!
Is your build plate removable?  this is the Mk3 printer thread, but the build plate doesn't look like mine...
washing the build plate on the printer is a bad idea.
I always detach my build plate and take it to the sink.
Veröffentlicht : 29/11/2023 11:52 pm
Kim Jones
(@kim-jones)
Okay,
I now cleansed the plate with Dishwashing Soap AND rubbed it off with Isopropyl. Great results!
Thanks again...
Veröffentlicht : 30/11/2023 12:48 pm
Kim Jones
(@kim-jones)
Thanks @joantabb
I only clean the plate on the sink and with kitchen wipes.
The build plate is a China one, true - but doesn't matter but it's cheaper with no shipping fees (Amazon)
Veröffentlicht : 30/11/2023 12:50 pm
I also use Chinese build plates...
do kitchen wipes leave an antibacterial film on the surface? if so, that may reduce adhesion
Veröffentlicht : 30/11/2023 12:52 pm
Hi Kim,
You probably don't need the additional IPA Wipe..
glad the dish soap worked.
Joan
Veröffentlicht : 30/11/2023 12:54 pm
Kim Jones
(@kim-jones)
Sorry, I didn't meant KITCHEN WIPE,
but solely paper roll for kitchen appliances
Veröffentlicht : 30/11/2023 1:09 pm
That's better!
Joan
Veröffentlicht : 30/11/2023 2:10 pm
