Print quality differences between two MK3Ss
I have 2 MK3S printers that I assembled. This photo shows a Benchy made on each printer with the same filament and same settings. The left Benchy is nearly perfect. The Benchy on the right has some dribbling issues on the overhanging bow section. Any suggestions for resolving this?
I've tried varying the temperature, but haven't found a good setpoint where the right printer behaves as consistently as the left printer.
This topic was modified 6 years ago by random.ae
Posted : 08/01/2020 10:49 pm
RE: Print quality differences between two MK3Ss
The pic link seems to be broken. Drag and drop images into the editor. Rotate the Benchy on the bad printer 90mdegrees and print again. If that helps, the fan duct may be the issue. The bow section is intended to test overhangs and temperatures.
Posted : 09/01/2020 2:25 am
