print gets stuck on the nozzle
Hi, I have been trying to figure out an issue. I just set up the new printer so maybe some calibration is off. I did do the xyz calibration.
When I try to print the marvin gcode it works great for a while and then it got stuck on the nozzle when it was creating the key chain.
Any idea why this is happening?
Thanks
Greg
Re: print gets stuck on the nozzle
Probably first layer issue or build plate needs cleaning
Regards Joan
90% isoprop alcohol does wonders for adhesion problems. Got to wipe down the bed before every print, and acetone one a week if you print heavy and notice prints stop sticking
Greg - Did this fix your problem? I have printed the whistle successfully but Marvin has failed three times almost exactly the same point...
