Preheat error
Hi, I have a problem, first it was overheating of the hotend, then I disassembled it and saw that the heatsink and heatblock were literally welded, I managed to separate them, I ordered a new heatsink and heatblock, put it together and started the printer and again it started to overheat the filament, changing from gray to a kind of golden color, I checked the fan for the heatsink and it seems to be working as it should, but again after a little while I see that the heatsink is getting hot and there is some problem that the nozzle temperature hardly exceeds 200 and it won't even go past 210
Este debate ha sido modificado el hace 2 months 2 veces por Miloš Vidaković
Respondido : 21/09/2025 5:25 pm
