Preheat error
Miloš Vidaković
(@milos-vidakovic)
Preheat error
Hi, I have a problem, first it was overheating of the hotend, then I disassembled it and saw that the heatsink and heatblock were literally welded, I managed to separate them, I ordered a new heatsink and heatblock, put it together and started the printer and again it started to overheat the filament, changing from gray to a kind of golden color, I checked the fan for the heatsink and it seems to be working as it should, but again after a little while I see that the heatsink is getting hot and there is some problem that the nozzle temperature hardly exceeds 200 and it won't even go past 210
This topic was modified 8 months ago 2 times by Miloš Vidaković
Posted : 21/09/2025 5:25 pm
