Overlapping Shell Lines....baffled
Oleg
 Oleg
(@oleg-2)
Hi All,
Assembled my MK3S and was printing without problems and excellent quality. However after having to rebuild the hotend due to a mishap, I have a problem I can't seem to troubleshoot. All of the horizontal shells in my prints, like the top surface, have what look like overlapping lines in them. They're perfectly straight in all directions. I was thinking over-extrusion causing the seams, but reducing the multiplier has done nothing...Tried slowing down the print thinking the printer was slightly over-shooting the start of the line, but that doesn't work either.
Any other ideas? Not sure what else to try. Thank you!
Best Answer by --:
It's a known issue in Prusa Slicer.  Any parts with holes in it will exhibit the problem.  Carefully calibrating the extrusion multiplier and filament diameter can help.
https://github.com/prusa3d/PrusaSlicer/issues/2556
Respondido : 01/12/2019 6:55 pm
RE: Overlapping Shell Lines....baffled
Respondido : 02/12/2019 1:49 am
1 les gusta
Steve
(@steve-3)
Lines like those will be present on a shape with holes and a rectilinear top layer.  Cura has an option called ironing that helps to hide the lines.  PrusaSlicer has an option under Print_Settings->Infill->Top_fill_pattern that can be changed from Rectilinear to Hilbert_Curve.
Steve
Respondido : 02/12/2019 3:17 am
1 les gusta
Oleg
 Oleg
(@oleg-2)
Thanks guys! Huge help.
Respondido : 03/12/2019 12:38 am
