Overlapping Shell Lines....baffled
Hi All,
Assembled my MK3S and was printing without problems and excellent quality. However after having to rebuild the hotend due to a mishap, I have a problem I can't seem to troubleshoot. All of the horizontal shells in my prints, like the top surface, have what look like overlapping lines in them. They're perfectly straight in all directions. I was thinking over-extrusion causing the seams, but reducing the multiplier has done nothing...Tried slowing down the print thinking the printer was slightly over-shooting the start of the line, but that doesn't work either.
Any other ideas? Not sure what else to try. Thank you!
Best Answer by --:
It's a known issue in Prusa Slicer. Any parts with holes in it will exhibit the problem. Carefully calibrating the extrusion multiplier and filament diameter can help.
RE: Overlapping Shell Lines....baffled
Lines like those will be present on a shape with holes and a rectilinear top layer. Cura has an option called ironing that helps to hide the lines. PrusaSlicer has an option under Print_Settings->Infill->Top_fill_pattern that can be changed from Rectilinear to Hilbert_Curve.
Steve
Thanks guys! Huge help.
