[Solved] Not completing Setup Wizard
Graham666
(@graham666)
I've recently purchased and assembled my printer and it passed the Wizard no problems. I’ve printed various samples off the SD card without issue.
I took the bed off to make some adjustments and refitted it I thought it best to run the wizard again. It does the fan test ok and the moves to the axes. It says ‘checking X axis’ and starts to move up in the Z and stops. It reports a self test error  and to Please check:  Axis length and says Axis X in the line below it. I’m not really understanding why it’s failing and also what I have to do to rectify the problem.
Posted : 14/11/2019 6:04 pm
RE: Not completing Setup Wizard
Check that the PINDA light is changing state when metal is placed near it. Also verify wires and cables are not contacting the frame (specifically the rat tail coming off the extruder). Common problems are obstructions like cable tie ends and wires; and bearings go dry in a few weeks after installation if they were not packed with grease before assembly.
Posted : 14/11/2019 7:03 pm
Graham666
(@graham666)
@tim-m30
Thanks for the reply Tim. I checked everything but all ok. In the end I went into settings and did the calibrate xyz and managed to reset everything. All part of the fun. 😀
Posted : 14/11/2019 11:03 pm
