Newbie print issues - help please
Just printed this as is with no adjustment using PLA but not sure what to adjust to try and correct the issue of stringing across the 2 USB and 1 Mini USB openings.
Im using a Mk3S+ printer with no mods. and the file was a .stl file
Any help would be appreciated.
Veröffentlicht : 07/01/2024 6:45 pm
Not knowing how big this object is, my first inclination would be to change the Infill→Advanced→Bridging Angle to 90 degrees so it bridges the short, not the long distance.
Veröffentlicht : 07/01/2024 9:02 pm
RE: Newbie print issues - help please
The smaller opening is around 8mm (5/16") the larger two openings around 15mm (5/8")
I will look into trying the bridging angle thank you.
Veröffentlicht : 07/01/2024 9:41 pm
