MMU2S Malfunction Load to nozzle does not work
cbz
 cbz
(@cbz)
I mounted the MMU2S module for the MK3S printer and I encounter 1 major problem
1 ) Load to nozzle does not work
The loading of the 5 filaments is OK, but the next step does not work.
Pulley alignment  is OK
Sonde FINDA is OK
        I tried different tightenings screws without success
        I manually tested the passage of each filaments by positioning the selector from 1 to 5. The filament passes without a hitch.
 If I run the command: "load to nozzle" no filament passes, it is 2 or 3 loading / unloading then hangs.
No response from support at this time.
Thank you in advance for your suggestions and for your help.
regards
Clément
Veröffentlicht : 06/06/2019 2:55 pm
cbz
 cbz
(@cbz)
RE: MMU2S Malfunction Load to nozzle does not work
Problem solved.
Seen with the support, the problem came from the IR sensor.
Setting it and OK
Clément
Veröffentlicht : 10/06/2019 2:48 pm
