MK3S Upgrade - Hotend loose
Sunshadow
(@sunshadow)
Hi!
I've got a problem with the upgrade from my MK3 to MK3S. After the assembly the hotend doesn't stay in a fixed position and can rotate around its axis. Any idea how to fix this problem?
Publié : 30/07/2019 7:49 pm
RE: MK3S Upgrade - Hotend loose
A bit of tape around the top of the heatsink would work. Or sandpaper the joint side of the front cover. Would tightem the top clamp.
Joan
Publié : 30/07/2019 8:49 pm
Sunshadow
(@sunshadow)
Thank you. Already found the problem! The hotend wasn't tightened enough with the heat sink 😉
Publié : 30/07/2019 10:05 pm
