MK3 --> MK3S Upgrade Kit -- Electronics assembly -- Step 4 -- "plug-aligner"
TurboCooler
(@turbocooler)
My kit did not come with this part.  Should I print this in PLA or PETG?
While the instructions say the file is available in g-code it is only in STL.  I can slice it but are there any recommendation on settings?
I have already assembled the upgrade so I will be going back to add the plug.
Some help with the above question would be appreciated.
Napsal : 06/04/2020 2:09 pm
vintagepc
(@vintagepc)
RE: MK3 --> MK3S Upgrade Kit -- Electronics assembly -- Step 4 -- "plug-aligner"
It doesn't matter. Its sole purpose is to keep you from mis-aligning the plug. If your printer works already you may as well leave it out.
Napsal : 06/04/2020 2:40 pm
TurboCooler
(@turbocooler)
@vintagepc
I understand that it now works.  I would like to add the part so I do not cause myself a future problem.  What I really want to know is PLA or PETG for the part?
Napsal : 06/04/2020 4:28 pm
It doesn't matter!
Napsal : 06/04/2020 9:00 pm
