Melting/Deforming R4 Extruder Cover on MK3S
Bendermk6
(@bendermk6)
i recently upgraded my MK3 with the Upgrade-Kit and self printed R4 parts (gCode from Prusa).
After all calibration, i printed a PLA (210°/62°) benchy for ~2.5h. I noticed that the new R4 "Extruder Cover" starts deforming on the right side. I thought that maybe the self printed parts had some issues, so i printed the Bxtruder Body, Cover and two other small parts again in PETG (240°/90°) for ~4h.
Now the Cover looks even more like its going to melting away within the next few printing hours. Should i be concern about a wrong assembly or something? Somebody else had this melting/deforming extruder cover. I add some pictures of the R4 Cover and my old stock B7 parts that had seen like 24days of printing and no to little deforming.
https://photos.app.goo.gl/ziqSxGDGAe9JDnNg6
Posted : 23/06/2019 7:16 am
Bunny Science
(@bunny-science)
RE: Melting/Deforming R4 Extruder Cover on MK3S
Unfortunately, that is a community known issue with the R4 extruder design. You are not alone. Prusa is reportedly going to address the problem.
Bunnies have a temporary solution that may keep you running until Prusa has a new design.
BS Hot Fins and Anti-sag PINDA for MK3S R4 Extruder
https://www.thingiverse.com/thing:3645975
You can print multiple hot fins in PETG as a temporary fix if you can't print polycarb or ABS
A more definitive solution is moving to a completely different airflow design like a BNBSX extruder, but that is only suitable for a well experienced builder.
This post was modified 7 years ago 2 times by Bunny Science
Posted : 24/06/2019 6:04 am
vintagepc
(@vintagepc)
I recently built a skelestruder and actually noticed quite a lot of melting on my R4 parts... X carriage, rear half of the extruder body (not just thin regions, dead center in the thick plastic) and the mentioned fins, in addition to a tiny bit of sag on the ABS fan shroud. Seems R4 has some serious airflow design problems.
Posted : 24/06/2019 10:55 am
vintagepc
(@vintagepc)
I think we may have to also consider low-temp PETGs as culprits too; I'm already seeing some droopage on my skelestruder hotfins after only a handful of prints. I used hatchbox and Amazon PETG which prints around 235 as opposed to other PETGs that print at higher temps (e.g. prusament at 250C)
Posted : 27/06/2019 12:03 pm
