life adjust Z - my way
Página 24 / 51
Mustrum Ridcully
(@mustrum-ridcully-2)
Re: life adjust Z - my way
Thanks Bob I will do so after this print is done and see if it locks things down I would not have thought of that one. good detective work on figuring it out.
Respondido : 12/12/2018 6:28 pm
Let us know if that fixes your problem. It would be good to have a definitive confirmation!
Respondido : 12/12/2018 7:59 pm
Miembro
Thanks for your efforts. This thread has helped me immensely.
Respondido : 13/12/2018 2:49 am
Tinkerwest
(@tinkerwest)
<r><QUOTE author="bobstro" post_id="119883" time="1544635337" user_id="51417"><s></s>
<QUOTE author="randolph.l" post_id="119880" time="1544633179" user_id="85468"><s></s>
[...] any thoughts on what is going on here?
<e>
</e></QUOTE>This may have been mentioned before, but someone posted that running the on-board Live-Z adjustment to completion is required at least once to set a flag to avoid drift between power cycles. I make a point of doing so any time I upgrade firmware, so haven't had the issue, but drifting Live-Z seems to happen. This will hopefully help.
<e>
</e></QUOTE>
Please explain what “on-board Live-Z adjustment to completion ” is. Is this running the build in Z Calibration from the LCD menu.</r>
Respondido : 13/12/2018 2:54 am
[...] Please explain what “on-board Live-Z adjustment to completion ” is. Is this running the build in Z Calibration from the LCD menu.</r>
Yes.
Respondido : 13/12/2018 4:06 am
wezzix
(@wezzix)
I had huge problems with bad adhesion, even after the Wizard first layer correction had run with what I thought was satisfactory results. Here you can see my calibration process in one single go. That in addition to dishwasher liquid and sponge cleaning made all the difference.
680 stuck terribly bad. 750 had slight gaps. 850 had hairs and blobs sticking out. 775 was the sweet spot.
Thank you for the gcode and advice! 😀
Respondido : 18/12/2018 8:24 pm
Mustrum Ridcully
Bump to put this back on the first page. perhaps it should be pinned?
Respondido : 30/12/2018 10:52 pm
toaf
 toaf
(@toaf)
ya, gotta keep this page around.
it's all about the Z baby!
Respondido : 31/12/2018 3:01 am
lee.k5
(@lee-k5)
What is meant when people are saying -500um, etc. I’m not too familiar with this and I have my current Z set at -1.130
Thanks!
Respondido : 09/01/2019 5:37 am
Bunny Science
(@bunny-science)
-500 micrometers (um) is -0.500 mm
your Z is -1.130 mm or -1130 um
Respondido : 09/01/2019 6:43 am
gnat
 gnat
(@gnat)
Had to factory reset so now I'm having to adjust my Z. This thread is FAR better than the test the printer itself does. Thank you.
Am I correct that the height of this print should be .2mm when it is perfect? Even if a lower Z value produces a better looking result?
For example a 0.750 setting looks like it has me at .22mm for the thickness while a 0.800 setting is .3mm, but has a better finish.
Just want to make sure I understand all this correctly.
MMU tips and troubleshooting
Respondido : 12/01/2019 12:17 am
Patrick McNamara
(@patrick-mcnamara)
That's my understanding. You could be over extruding slightly.
Respondido : 12/01/2019 4:34 pm
roberto.a5
(@roberto-a5)
Hi all,
thanks for your help.
I am a super newbie owner of MK3 kit.
I am trying to do this fine adjustment, but without success.
I run the PLA gcode attached from the SD card, it starts with the calibration and executes it successfully, then set the temperature at the designed level and then it shuts down without printing.
What am I missing?
Respondido : 13/01/2019 3:32 pm
Chocki
(@chocki)
Also be careful if you have the textured PEI surface as you will get slightly thicker measuring prints due to the non flat surface, I typically get 0.23 to 0.25 with a good first layer, even though supposedly i am printing a 0.2 layer.
Respondido : 14/01/2019 9:28 pm
Mustrum Ridcully
bump to keep on first page.
Moderators how about sticking this thread so we don't have to bump it every few weeks
Respondido : 26/01/2019 2:17 am
MatsErik
(@matserik)
I am using a 45 degree narrow plane in my live Z adjust as I do not care for waiting until I see the print.
Respondido : 26/01/2019 12:25 pm
Mustrum Ridcully
bump back to first page would a monitor please pin this thread?
Respondido : 08/02/2019 10:49 pm
John
 John
(@john-6)
Randolph I agree but a new locked thread should be started with the procedure and the test files added plus a link this thread. This is way too long. And a non typo subject heading.
The same same for cleaning. These are the two threads which occur over and over.
Also as this thread has gone on for so many pages do moderators still visit ?
John
i3 Mk3 [aug 2018] upgrade>>> i3MK3/S+[Dec 2023]
Respondido : 08/02/2019 11:13 pm
Mustrum Ridcully
be patient ;-).
i generated the gcode with simplify3d's default settings for printers. they first heat up the print surface and when the bed temperature is reached, the nozzle starts to heat.
Is there anything special about adding the 7x7 Start Gcode to this set of gcode test files
S3D_calibration_surfaces_75x75@200um_v6.1.zip ?
Do I just open them each in a text editor search for:
G80
and then change those lines to
G80 N7 ; mesh bed leveling 7x7
just checking before I do something dumb.
or would I be better off looking for your STL file somewhere in the 48 pages of this post and slicing it with the Prety PETG settings from CW on the facebook community forum, with the slic3r Alpha5
Respondido : 16/02/2019 2:48 am
RichBeck
(@richbeck)
Thanks for this file, it solved a problem that just cropped up.
I cleaned the print beds with acetone because prints were curling up. Probably from removing prior prints too soon before they were fully released.
I used your file and got a great result from my new z setting.
I have to admit I panicked a bit when I was watching the screen and it set the temp for the extruder to 170. I immediately tuned to 225 and let it print and it worked.
I then checked your gcode and saw that you had it move up to 225 before starting the calibration print.
Just curious, why do you have it go to 170 first?
Respondido : 21/02/2019 5:56 pm
Página 24 / 51
