Layer Shift along y axis
I just finished building my mk3 printer a day ago and ran a few prints on the SD card and they were awesome. Only recently I noticed a shift in the y axis of my prints. The only thing I can think of is maybe I changed a setting in software in Slic3r PE. I am hoping to get some suggestions on troubleshooting steps. I did adjust acceleratation in the slicer and that appears to have helped.
Posted : 30/08/2018 11:05 pm
Re: Layer Shift along y axis
check belt tension, check the Gt2 pully is still attached and the grub screw didnt loosen. Make sure the u bolts are not loose.
EDIT: check belt tension physically, mine has in the past not updated the number it displays on the LCD even after belt has got very loose. Make sure by hand that it is still tight.
Posted : 31/08/2018 12:31 am
