Just received the prebuilt i3 mk3s, filament does not extrude and the extrude is making clicking noises.
When I look at the gears that feed the filament in, I can see them clicking.
Posted : 25/03/2019 4:44 pm
Re: Just received the prebuilt i3 mk3s, filament does not extrude and the extrude is making clicking noises.
That's a pretty terse description of a complex problem, so you're going to have to put a bit more effort into your question if a lucky guess doesn't nail it...
1. Have you been printing? If so, check for clogs. Do a cold pull.
2. If you haven't been printing, are you sure the extruder screws are tight enough to grip the filament. Trim the filament and re-insert, then try adjusting the screws so the heads protrude approx. 1mm from the cover and it should have sufficient tension to pull the filament in.
Good luck.
Posted : 25/03/2019 9:41 pm
My guess is you have not trimmed the leading point of the filament to a sharp mitre and are trying to load a blunt point, blob or kink
i3 Mk3 [aug 2018]
Posted : 26/03/2019 1:53 pm
