Just got my kit.. build was going good until I ran into a bad Trapezoidal Nut 🙁
jerryn
(@jerryn)
I have one trapezoidal nut that has bad threads. This put the breaks on the assembly today.  Later on I'm going to head out and get a tap and see if I can fix it.
Apparently this problem has been going on for a while since the original.  If there's an automated spin test of the trapezoidal nut then you need to increase the torque sensitivity.  If the process isn't automated and involves a human testing then I suggest hiring some older school aged kids that want to earn some money and widen the test sample.  It appears that there's a high defect rate with the trapezoidal nuts.
Postato : 24/10/2022 8:49 pm
Contact Prusa Support:
Log into your Eshop account, navigate to Help and live chat is at bottom right in most browsers. If not you may need to disable your ad-blocker temporarily.
Postato : 24/10/2022 10:55 pm
Netpackrat
(@netpackrat)
Check your spares bag.  I seem to remember there having been one in mine.
Also, when you make suggestions on this user forum for improvements that Prusa could make to their processes, they probably aren't listening.
https://www.printables.com/@Netpackrat/models
Postato : 25/10/2022 12:11 pm
jerryn
(@jerryn)
RE: Just got my kit.. build was going good until I ran into a bad Trapezoidal Nut 🙁
That was the first thing I did.  I'll check again, just in case.
Postato : 25/10/2022 12:22 pm
Artur5
(@artur5)
For sure my kit came with a spare trapezoidal nut. Being rather small it could be mixed in a bag with other spare plastics parts and you missed it.  Just saying..
Postato : 25/10/2022 4:30 pm
TMS
 TMS
(@tms)
Mine were in the box with the stepper motors, if I recall correctly.
Postato : 26/10/2022 1:55 am
