Just got a new MK3S+ but SD card doesn’t come with it.
Koon
 Koon
(@koon)
Hi guys, so I just bought the MK3s+ but the supplied SD card didn’t come with. Are there any important info, notes, apps, models in that SD card? Can I get a link to those files? (I did some searching here, found an old thread, those links to the files were no longer accessible)
thanks in advance guys!
best,
koon
Posted : 29/04/2022 5:45 pm
JustMe3D
(@justme3d)
there´s only sample gcode files on the SD card, such as the very initial prints you want to run for testing, such as the famous Benchy and the Prusa Plate. All of these are available on Prusa´s platform printable.com, select the search for prints offered by "Prusa Research" and you´re good to go (the link gets you there, just scroll down to find the right files). Typically you would download "Model Files", i.e. .3mf or .stl files to slice them yourself with Prusa Slicer or other slicer programs, resulting in a gcode file to your liking, but Prusa has uploaded "Print Files", i.e. readily sliced gcodes for these files too, easy to use for beginners, just make sure you select the version made for your printer. Format an SD-card to FAT32, copy the gcode file to the card and happy printing....
Posted : 29/04/2022 8:25 pm
sylviatrilling
(@sylviatrilling)
RE: Just got a new MK3S+ but SD card doesn’t come with it.
If you have installed PrusaSlicer, you should have a folder called  Original Prusa Drivers. Inside that should be a folder called Objects which will contain sample gcodes and .stls.
Mk3S+,SL1S
Posted : 29/04/2022 8:35 pm
Koon
 Koon
(@koon)
Thank you all!
Posted : 09/05/2022 6:19 pm
dhiltonp
(@dhiltonp)
The SD card should be in the black bag the panel came in.
Posted : 10/05/2022 12:17 am
