Issues with gaps
So when I try to do a large flat print or two I run into this issue of patches of gaps they look to be inside the filament lines. I posted in another place and had a few suggestions since then I have checked the z level (any lower and the lines will becomes blobby, I have recently made the frame more straight, leveled the bed using the nylock nut method and also did a cold pull but no luck. Been looking online and cannot seem to find a post with the same issue. Thanks for reading.
Veröffentlicht : 12/03/2022 11:47 pm
RE: Issues with gaps
forgot to add this is with pla on the standard settings, .15 and 0.3 thickness
Veröffentlicht : 13/03/2022 8:26 pm
