Is my Filament Sensor Toast?
Recently Built MK3s+...when I try to print...it beeps then tells me to unload/reload filament....never prints. If I disable the Filament sensor, it does its purge line then starts print...not sure whats going on...any advice
Posted : 23/03/2021 5:40 am
RE: Is my Filament Sensor Toast?
Could be a faulty filament sensor, other possible cause is the cable routing, very easy to trap this cable when building the extruder, and also when fitting the back plate onto the extruder.
There is a troubleshooting document for it, that includes other possibilities as well
Prusa Knowledge Base | IR Filament Sensor Troubleshooting (MK2.5S, MK3S) (prusa3d.com)
Hope this helps
Tank you very much!
Posted : 23/03/2021 8:57 pm
