Im unable to draw circles weird straight pattern
Krone
(@krone)
Hello everyone!
I am new to the community and I'm having issues with my MK3 printer. It has been working for approx a year without issues, but suddenly it makes weird patterns in the printing. I tried making some circles to test it out and I get this weird straight pattern aligned around the circles.
I can't seem to figure out what the issue might be. The belt's tension is 255 y-axis and 257 x-axis so the belt should be in the correct tension span.
Printing is  PLA 215/60 Quality 0.15.
The circles are just for testing this issue also interfere with other prints.
attached some photos for reference
Thanks in advance 🙂
This topic was modified 4 years ago by Krone
Posted : 21/04/2022 8:02 am
misan
(@misan)
Member Moderator
I would check for loose pulleys on X & Y axes motors.
And check belt tension too: https://help.prusa3d.com/en/article/adjusting-belt-tension-mk3-s_112380
This post was modified 4 years ago by misan
Posted : 21/04/2022 8:14 am
Krone
(@krone)
Thank you misan! The pulley was a little bit loose on the y-axes after a new wizard the circles are in perfect shape!
Posted : 21/04/2022 9:33 am
