How to attach pictures?
I'm having trouble with taller prints on a kit I completed yesterday. I'd like to attach pictures but can't figure out how to do it. Any tips on attaching pictures would be appreciated.
RE: How to attach pictures?
Zip pictures into zip file then go add media and upload zip
Thanks for that. I was trying to use "Insert/edit image"
No need to zip pictures. You just use the Add Media button, that will allow you to upload pictures to your personal gallery. You can then select any picture in your gallery to insert into a post. There are several options when adding them, like display as a smaller size, make then clickable etc.
Be aware that files uploaded to your gallery can be pruned at any point by prusa when they want to free up space. Thats why a lot of the older help posts that had very useful pictures are no longer helpful as the pics were deleted over time. The gallery/Add Media can store both images and zip files.
The insert image allows you to add one using a link, so the image has to already be uploaded somewhere on the internet for that to work. Also the site you are linking from has to allow cross linking. If you had pictures on some personal webspace and knew the address you could use the insert image option.
You can use the Attach File button to add a one time zip file without it being added to your gallery though (thats common for attaching zipped up 3mf project files when requesting help).
