Help the sensor isnt detecting the build plate
The sensor not detecting the build olate
RE: Help the sensor isnt detecting the build plate
How not detecting the bed looks like? What it does to you? During print, or still calibration?
First try the functionality of PINDA sensor. There should be a red light always on. If you put some metal object bellow, the red light will switch off.
During calabration it dosn't detect it and I have adjusted the pinda properly and the pinda works
@deestrong100
can we see a picture of the extruder near the printbed please?
Joan
Please post the image as Joan asked. Usually the PINDA is simply too high and lowering a bit solves the problem.
Hh
Try to lower PINDA a bit. Not much, just a little bit.
