RE: Help needed: Trouble printing thin parts
I had to do the same with Cura. Cura just fails for me.
Though I have so say I like Cura's graphical interface much better. Slicer is a tiny bit too technical and cluttered to some degree. But I guess it does not matter, the result is what counts.
That was quite an interesting journey.
3D Druck für Einsteiger leicht gemacht: www.3d-druck-lernen.de
Hello,
I again changed the settings using Prusa Slicer and I must say the results are awesome. Almost no noticeable stringing and perfect layers. I did adjust the settings as follows:
- Extruder temperature = 195° C
- Travel speed = 200 mm/s
- Retraction length = 1.0 mm
- Retraction speed = 40 mm/s
This is what it looks like right after:
After I removed the strings with a lighter:
I will have to try your settings.
If you need the STL file, just let me know.
