Help needed: Trouble printing thin parts
Seite 2 / 2
Mitglied
RE: Help needed: Trouble printing thin parts
I had to do the same with Cura.  Cura just fails for me.
Veröffentlicht : 01/10/2019 8:20 am
wieman01
(@wieman01)
Posted by: @charles-h13
Though I have so say I like Cura's graphical interface much better. Slicer is a tiny bit too technical and cluttered to some degree. But I guess it does not matter, the result is what counts.
That was quite an interesting journey.
3D Druck für Einsteiger leicht gemacht: www.3d-druck-lernen.de
Veröffentlicht : 01/10/2019 8:22 am
wieman01
(@wieman01)
Hello,
I again changed the settings using Prusa Slicer and I must say the results are awesome. Almost no noticeable stringing and perfect layers. I did adjust the settings as follows:
  • Extruder temperature = 195° C
  • Travel speed = 200 mm/s
  • Retraction length = 1.0 mm
  • Retraction speed = 40 mm/s
This is what it looks like right after:
After I removed the strings with a lighter:
Diese r Beitrag wurde geändert Vor 5 years 2 mal von wieman01
Veröffentlicht : 01/10/2019 9:03 am
Mitglied
I will have to try your settings.
Veröffentlicht : 01/10/2019 10:36 am
wieman01
(@wieman01)
If you need the STL file, just let me know.
Veröffentlicht : 01/10/2019 12:27 pm
Seite 2 / 2
