					                		Greasing Linear Bearing Tool - Assembly and first prints troubleshooting                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/greasing-linear-bearing-tool/</link>
                <lastBuildDate>Mon, 11 May 2026 21:26:57 +0000</lastBuildDate>
                        <title>RE: Greasing Linear Bearing Tool</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/greasing-linear-bearing-tool/#post-399646</link>
                        <pubDate>Sat, 20 Mar 2021 17:55:30 +0000</pubDate>
                        <description><![CDATA[Ahh thanks for the reply’s everyone - great help.Thanks @clarmrrsn for the info, ill be sure to do it that way when setting up. 🤩 It looks like your right @loak - buy looking at that step th...]]></description>
                        <content:encoded><![CDATA[<p>Ahh thanks for the reply’s everyone - great help.</p><p>Thanks @clarmrrsn for the info, ill be sure to do it that way when setting up. 🤩 </p><p>It looks like your right @loak - buy looking at that step they must now include that tool within the pack assembly pack.... will find out in a week or so once  mine clears UK customs! 😀 😀 😀 😬 </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Dickdickharris</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/greasing-linear-bearing-tool/#post-399646</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/greasing-linear-bearing-tool/#post-399640</link>
                        <pubDate>Sat, 20 Mar 2021 17:48:42 +0000</pubDate>
                        <description><![CDATA[@clarmrrsnOK, good catch, thanks for posting that; I had not seen it before. Glad I used a grease that is safe for plastics (Super Lube).Thanks,Ted]]></description>
                        <content:encoded><![CDATA[<p>@clarmrrsn</p><p>OK, good catch, thanks for posting that; I had not seen it before. Glad I used a grease that is safe for plastics (Super Lube).</p><p>Thanks,<br />Ted</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Technical Ted</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/greasing-linear-bearing-tool/#post-399640</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/greasing-linear-bearing-tool/#post-399433</link>
                        <pubDate>Sat, 20 Mar 2021 14:17:05 +0000</pubDate>
                        <description><![CDATA[@cwbulletWas a massive difference Chuck.They were very grumbly vs nice and smooth after using this technique, I don&#039;t suppose this would help print quality much.Begs the question as to wheth...]]></description>
                        <content:encoded><![CDATA[<p>@cwbullet</p><p>Was a massive difference Chuck.</p><p>They were very grumbly vs nice and smooth after using this technique, I don't suppose this would help print quality much.</p><p>Begs the question as to whether you should be removing and regressing the bearings every xxx hours. </p><p>Easier to mark the bearings before packing them, makes it more tricky to mark them after packing.  Especially with my eyesight 🥸</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Clarmrrsn</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/greasing-linear-bearing-tool/#post-399433</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/greasing-linear-bearing-tool/#post-399409</link>
                        <pubDate>Sat, 20 Mar 2021 14:01:34 +0000</pubDate>
                        <description><![CDATA[Posted by: @technical-ted I also put a small amount of grease on the Z screws. Not a lot....Another point is for the needle bearings and gear teeth for the extruder. In the supplied &quot;3D Prin...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="253927" data-postid="399265" data-mention="technical-ted"><div class="wpforo-post-quote-author"><strong> Posted by: @technical-ted </strong></div><p>I also put a small amount of grease on the Z screws. Not a lot....</p><p>Another point is for the needle bearings and gear teeth for the extruder. In the supplied "3D Printing Handbook" in the maintenance section, it tells about greasing them. I greased mine during assembly. Why later but not now during assembly??? Didn't make sense to me. Just don't get grease in the filament drive grooves.</p><p>Ted</p><p> </p></blockquote><p>Apparently lubrication of the z screws can cause problems, they are self lubricating due to the material they are made from.</p><p>Check the reply from prusa in the comments section.</p><p>https://help.prusa3d.com/en/guide/printer-maintenance-tips_23200</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/greasing-linear-bearing-tool/#post-399409</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/greasing-linear-bearing-tool/#post-399403</link>
                        <pubDate>Sat, 20 Mar 2021 13:47:21 +0000</pubDate>
                        <description><![CDATA[@clarmrrsnThat is good info.  I might have to lubricate mine this week.]]></description>
                        <content:encoded><![CDATA[<p>@clarmrrsn</p><p>That is good info.  I might have to lubricate mine this week.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>cwbullet</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/greasing-linear-bearing-tool/#post-399403</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/greasing-linear-bearing-tool/#post-399388</link>
                        <pubDate>Sat, 20 Mar 2021 13:25:13 +0000</pubDate>
                        <description><![CDATA[Glad to see Prusa is changing their position on this.  When I assembled by MK3S+, I used the Prusa grease to lubricate the bearings as others had suggested.  I still felt odd about it becaus...]]></description>
                        <content:encoded><![CDATA[<p>Glad to see Prusa is changing their position on this.  When I assembled by MK3S+, I used the Prusa grease to lubricate the bearings as others had suggested.  I still felt odd about it because I did it differently than Prusa's assembly instructions.  Now I can stop worrying about it. 😀 </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>egar</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/greasing-linear-bearing-tool/#post-399388</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/greasing-linear-bearing-tool/#post-399283</link>
                        <pubDate>Sat, 20 Mar 2021 11:49:29 +0000</pubDate>
                        <description><![CDATA[That&#039;s good news.Still think the method above is far more effective at driving the grease in and around the ball races.And as this info did come from Prusa maybe they will update the mk3 man...]]></description>
                        <content:encoded><![CDATA[<p>That's good news.</p><p>Still think the method above is far more effective at driving the grease in and around the ball races.</p><p>And as this info did come from Prusa maybe they will update the mk3 manual to include these instructions in the future.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/greasing-linear-bearing-tool/#post-399283</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/greasing-linear-bearing-tool/#post-399280</link>
                        <pubDate>Sat, 20 Mar 2021 11:44:56 +0000</pubDate>
                        <description><![CDATA[Hi,When it comes to lubricating the linear bearings, Prusa seems to be slowly changing his mind as can be seen on this page, steps 6 to 8.]]></description>
                        <content:encoded><![CDATA[<p><span class="VIiyi" lang="en"><span class="JLqJ4b ChMk0b" data-language-for-alternatives="en" data-language-to-translate-into="auto" data-phrase-index="0">Hi,</span></span></p><p><span class="VIiyi" lang="en"><span class="JLqJ4b ChMk0b" data-language-for-alternatives="en" data-language-to-translate-into="auto" data-phrase-index="0">When it comes to lubricating the linear bearings, Prusa seems to be slowly changing his mind as can be seen on <a href="https://help.prusa3d.com/en/guide/3-x-axis-extruder-assembly_199519" target="true">this page</a>, steps 6 to 8.<br /></span></span></p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Loak</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/greasing-linear-bearing-tool/#post-399280</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/greasing-linear-bearing-tool/#post-399265</link>
                        <pubDate>Sat, 20 Mar 2021 11:27:13 +0000</pubDate>
                        <description><![CDATA[I also put a small amount of grease on the Z screws. Not a lot....Another point is for the needle bearings and gear teeth for the extruder. In the supplied &quot;3D Printing Handbook&quot; in the main...]]></description>
                        <content:encoded><![CDATA[<p>I also put a small amount of grease on the Z screws. Not a lot....</p><p>Another point is for the needle bearings and gear teeth for the extruder. In the supplied "3D Printing Handbook" in the maintenance section, it tells about greasing them. I greased mine during assembly. Why later but not now during assembly??? Didn't make sense to me. Just don't get grease in the filament drive grooves.</p><p>Ted</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/greasing-linear-bearing-tool/#post-399265</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/greasing-linear-bearing-tool/#post-399205</link>
                        <pubDate>Sat, 20 Mar 2021 09:44:36 +0000</pubDate>
                        <description><![CDATA[@dawsonCompletely agree, this needs to be in the manual to avoid these types of scenarios.I stripped the Y and X axis down again, but had only just completed the Z axis assembly, didn&#039;t take...]]></description>
                        <content:encoded><![CDATA[<p>@dawson</p><p>Completely agree, this needs to be in the manual to avoid these types of scenarios.</p><p>I stripped the Y and X axis down again, but had only just completed the Z axis assembly, didn't take too long to do in all honesty.</p><p>Not sure it is necessary if you left the shipping oil on, should suffice.</p><p> </p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/greasing-linear-bearing-tool/#post-399205</guid>
