					                		Ghosting, VFA or something else? - Assembly and first prints troubleshooting                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/ghosting-vfa-or-something-else/</link>
                <lastBuildDate>Sun, 14 Jun 2026 03:50:42 +0000</lastBuildDate>
                        <title>RE: Ghosting, VFA or something else?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/ghosting-vfa-or-something-else/#post-200497</link>
                        <pubDate>Thu, 19 Mar 2020 08:02:29 +0000</pubDate>
                        <description><![CDATA[After having been printing happily with Ultimakers for years I finally decided to give a simpler printer a go as I was hearing good things about Prusa.Now I don&#039;t know what a Prusa should pr...]]></description>
                        <content:encoded><![CDATA[<p>After having been printing happily with Ultimakers for years I finally decided to give a simpler printer a go as I was hearing good things about Prusa.</p><p>Now I don't know what a Prusa should print like. Maybe this is as good as it can do, but I was hoping for more.</p><p>I've just assembled my printer yesterday and am seeing the exact same thing.</p><p>So far I've tried to:</p><p>- Take a bit of tension of the belts</p><p>- Print a e linearity tower, but for me the best results are with it set to 0</p><p> </p><p><a href="https://forum.prusa3d.com/wp-content/uploads/2020/03/IMG_20200318_145156.jpg"><img class="alignnone size-medium wp-image-19546" src="https://forum.prusa3d.com/wp-content/uploads/2020/03/IMG_20200318_145156-600x500.jpg" alt="" width="600" height="500" /></a>  <a href="https://forum.prusa3d.com/wp-content/uploads/2020/03/IMG_20200318_145124-1.jpg"><img class="alignnone size-medium wp-image-19552" src="https://forum.prusa3d.com/wp-content/uploads/2020/03/IMG_20200318_145124-1-600x500.jpg" alt="" width="600" height="500" /></a></p><p> </p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>christianmccabe</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/ghosting-vfa-or-something-else/#post-200497</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/ghosting-vfa-or-something-else/#post-198051</link>
                        <pubDate>Sun, 08 Mar 2020 14:09:54 +0000</pubDate>
                        <description><![CDATA[Another quick update.I&#039;ve done several other tests. I&#039;ve tried different types of feet, rigid, absorbing, and the factory ones. I&#039;ve moved the printer to a marble base 45x45x6 cm. Weight 30 ...]]></description>
                        <content:encoded><![CDATA[<p>Another quick update.</p><p>I've done several other tests. I've tried different types of feet, rigid, absorbing, and the factory ones. I've moved the printer to a marble base 45x45x6 cm. Weight 30 kg!</p><p>Long story short: the quality cannot be improved. The only way to improve the print is to lower the speed. It looks like that 15-20 mm/s for external perimeters is the best parameter you can use.</p><p>I think the real problem is the x-axis and x-carriage stability. The two rods are not so stable (eg. you can easily move the x-carriage 1-2 mms on the Y-axis). That's the reason why I'm getting ghosting especially in the movements that are simultaneously involving X and Y movements.</p><p>Example of a 45 deg perimeters. Up: 30 mm/s with different acceleration(200 to 1000mm/s2), Bottom 40 mm/s.</p><p><a href="https://forum.prusa3d.com/wp-content/uploads/2020/03/IMG_5319.jpg"><img class="alignnone size-medium wp-image-17998" src="https://forum.prusa3d.com/wp-content/uploads/2020/03/IMG_5319-600x500.jpg" alt="" width="600" height="500" /></a></p><p><a href="https://forum.prusa3d.com/wp-content/uploads/2020/03/IMG_5320.jpg">Example of only x movement perimeter</a></p><p><a href="https://forum.prusa3d.com/wp-content/uploads/2020/03/IMG_5320.jpg"><img class="alignnone size-medium wp-image-18001" src="https://forum.prusa3d.com/wp-content/uploads/2020/03/IMG_5320-600x500.jpg" alt="" width="600" height="500" /></a></p><p>Best</p><p>R</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Zuli</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/ghosting-vfa-or-something-else/#post-198051</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/ghosting-vfa-or-something-else/#post-196155</link>
                        <pubDate>Fri, 28 Feb 2020 20:43:07 +0000</pubDate>
                        <description><![CDATA[Same as Vintagepc, I to have a skelestruder with 3.5:1 gearing fitted with 1.8 Deg motor and both X + Y have 0.9 Deg motors and even with all this I can never get a truly smooth surface and ...]]></description>
                        <content:encoded><![CDATA[<p>Same as Vintagepc, I to have a skelestruder with 3.5:1 gearing fitted with 1.8 Deg motor and both X + Y have 0.9 Deg motors and even with all this I can never get a truly smooth surface and yes, ringing is the most prominent visual artifact.</p><p>I am in the process of re-printing my printer parts more accurately now that I have some experience under my belt, to see if it improves anything, but mainly so that I have a spare set in case something breaks, and am going to use grease in the bearings instead of oiling as it is more viscous than oil and may help reduce ringing.</p><p>Here is my result before modifications and after modifications of going from standard 1.8 Deg motors on X and Y to 0.9 Deg motors and modified firmware.</p><p> <a href="https://forum.prusa3d.com/wp-content/uploads/2019/09/20190901_095857.jpg"><img class="alignnone size-medium wp-image-4395" src="https://forum.prusa3d.com/wp-content/uploads/2019/09/20190901_095857-300x300.jpg" alt="" width="300" height="300" /></a></p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Chocki</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/ghosting-vfa-or-something-else/#post-196155</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/ghosting-vfa-or-something-else/#post-196140</link>
                        <pubDate>Fri, 28 Feb 2020 19:40:18 +0000</pubDate>
                        <description><![CDATA[That appears to be extruder (non-)linearity. If the E-linearity calibration Bobstro mentioned does not affect it significantly, then really the only way to get rid of it is to change to a di...]]></description>
                        <content:encoded><![CDATA[<p>That appears to be extruder (non-)linearity. If the E-linearity calibration Bobstro mentioned does not affect it significantly, then really the only way to get rid of it is to change to a different extruder or extruder motor (0.9 degree steps). Personally I run a skelestruder with 3.5:1 gearing which eliminates that artifact nicely. </p><p>But beware, surface finish is a rabbit hole. The next thing that will show up is VFAs, which are reduced by changing the X/Y motors for 0.9 degree steppers, at that point ringing becomes the most prominent visual artifact. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>vintagepc</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/ghosting-vfa-or-something-else/#post-196140</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/ghosting-vfa-or-something-else/#post-196133</link>
                        <pubDate>Fri, 28 Feb 2020 18:53:25 +0000</pubDate>
                        <description><![CDATA[Quick update.I&#039;ve replaced the X bearings and the Y bearings with new fully lubricated bearings. I&#039;ve done the full calibration.I&#039;ve reprinted the benchy. Same ghosting, same pattern, same r...]]></description>
                        <content:encoded><![CDATA[<p>Quick update.</p><p>I've replaced the X bearings and the Y bearings with new fully lubricated bearings. I've done the full calibration.</p><p>I've reprinted the benchy. Same ghosting, same pattern, same result :( </p><p>I'm running out of options and ideas.</p><p> </p>
<div id="wpfa-16651" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//forum.prusa3d.com/wp-content/uploads/wpforo/default_attachments/1582916005-IMG_5289.jpg" target="_blank"><i class="fas fa-paperclip"></i>&nbsp;IMG_5289.JPG</a></div>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/ghosting-vfa-or-something-else/#post-196133</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/ghosting-vfa-or-something-else/#post-195543</link>
                        <pubDate>Wed, 26 Feb 2020 08:53:42 +0000</pubDate>
                        <description><![CDATA[@chocki @lichtjaeger: I&#039;ve read the article you&#039;ve suggested. It says that &quot;One of the many misconceptions about bearings is they need to have zero friction. This is why people like Igus bea...]]></description>
                        <content:encoded><![CDATA[<p>@chocki @lichtjaeger: I've read the article you've suggested <a title="here" href="https://prusacommunity.com/set-your-bearing-straight/" target="true">https://prusacommunity.com/set-your-bearing-straight/</a> . It says that "One of the many misconceptions about bearings is they need to have zero friction. This is why people like Igus bearings. The problem is when you have no friction you also don’t have smooth acceleration or deceleration. Basically the less friction the greater the backlash. So yes, Igus bearings hurt your print quality. I said it and I’ll say it every time. If you like sloppy bearings and lots of additional ringing in your prints or lots of overshoot then feel free ..."</p><p>So I'm not understanding if I should look for better greasing or better friction 🤔 </p><p>@chocki @bobstro: I've already tried to move the printer to the floor, to use felts, to feed the filament by hand from above the printer without the reel on top. Without success :(</p><p>@bobstro: I've did the extruder linearity and it looks like I'm not needing correction so far. Regarding the cube. It's 5cm x 5cm x5cm. I wanted to have a longer side to diagnose problems</p><p>@chocki: I'm going to try this: <a class="wpforo-auto-embeded-link" href="http://www.desiquintans.com/ringing" target="_blank" rel="nofollow noopener">http://www.desiquintans.com/ringing</a>.</p><p>Guys, thank you so much for your help!</p><p>This is an awesome community!</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/ghosting-vfa-or-something-else/#post-195543</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/ghosting-vfa-or-something-else/#post-195494</link>
                        <pubDate>Tue, 25 Feb 2020 22:18:32 +0000</pubDate>
                        <description><![CDATA[Posted by: @riccardo-zulian I&#039;m trying to investigate why, if I set an &quot;external perimeter speed&quot; equal to 15 mm/s or less, ghosting is disappearing.I&#039;m going to focus on slicer settings as ...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="146434" data-postid="195387" data-mention="riccardo-zulian"><div class="wpforo-post-quote-author"><strong> Posted by: @riccardo-zulian </strong></div><p>I'm trying to investigate why, if I set an "external perimeter speed" equal to 15 mm/s or less, ghosting is disappearing.</p></blockquote><p>I'm going to focus on slicer settings as I don't see anything in your pics that looks unusual.</p><p>Slowing down perimeter speeds does several things:</p><ul><li>It reduces the effect of acceleration and jerk between turning a corner and moving the nozzle up to full speed. Acceleration and jerk are well-known contributors to ghosting. This is more of a happy side effect. Prusa has made significant changes to the Mk3 acceleration and jerk settings since original release.</li><li>It reduces bed sway on direction changes. Compare faces on the X &amp; Y walls to see if movement of the heavy bed impacts the severity of ghosting.</li><li>It gives the filament more time to heat and extrude evenly. This is more of an issue with adhesion.</li></ul><p>You can try the <a href="https://help.prusa3d.com/en/article/extruder-linearity-correction-calibration_2254" target="true">extruder linearity correction calibration procedure</a> to see it if helps with the moire patterning. I found it beneficial. It's always hard to tell from pics if this is a problem or just a lighting issue.</p><p>Did you notice any change moving the printer onto the floor? A vibrating surface can contribute to issues. I wound up mounting my Mk3 on a concrete paver when I moved it to a cabinet.</p><p>Edit: How big is that XY cube? It looks large in the pics.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>bobstro</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/ghosting-vfa-or-something-else/#post-195494</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/ghosting-vfa-or-something-else/#post-195411</link>
                        <pubDate>Tue, 25 Feb 2020 17:50:02 +0000</pubDate>
                        <description><![CDATA[And have a read of this and maybe play with your jerk values. Prusa seem to vary these between firmwares.If you have carried out modifications, it cant hurt to try values around the PRUSA se...]]></description>
                        <content:encoded><![CDATA[<p>And have a read of this and maybe play with your jerk values. Prusa seem to vary these between firmwares.</p><p>If you have carried out modifications, it cant hurt to try values around the PRUSA settings to see if your particular setup benefits from a slight tweak.</p><p><span style="background-color: #ffffff">http://www.desiquintans.com/ringing</span></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/ghosting-vfa-or-something-else/#post-195411</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/ghosting-vfa-or-something-else/#post-195403</link>
                        <pubDate>Tue, 25 Feb 2020 17:24:57 +0000</pubDate>
                        <description><![CDATA[Do you still have your filament on top of your printer?, try a reverse Bowden setup, initially, just feed the filament by hand from above the printer without the reel on top and see if this ...]]></description>
                        <content:encoded><![CDATA[<p>Do you still have your filament on top of your printer?, try a reverse Bowden setup, initially, just feed the filament by hand from above the printer without the reel on top and see if this helps, the idea is to reduce shaking of the printer, also those soft feet PRUSA supply are not the best for reducing wobbling, ideally you want to print some rigid feet and put felt pads like the ones for furniture on the bottom, then place your printer on a heavy solid base like a slab or granite chopping board. You actually want to add fixed mass to the printer to stop it moving about.</p><p> </p><p>Iv'e actually considered bolting heavy weights to the side of my printer, but ultimately it depends on what you are trying to print, if perfect test pieces is your goal, then you will be chasing the never ending nirvana for a long time, there comes a time, when you have improved your prints to a level that is acceptable and cost is not exorbitant.</p><p> </p><p>For me this was reverse Bowden feed, granite chopping board, solid feet with felt pads, skelestruder, better pulleys and probably the biggest improvement for me anyway, 0.9 deg OMC stepperonline X + Y motors.</p><p>I am going to try <span style="float: none;background-color: #ffffff;color: #333333;cursor: text;font-size: 16px;font-style: normal;font-variant: normal;font-weight: 400;letter-spacing: normal;text-align: left;text-decoration: none;text-indent: 0px;text-transform: none">some misumi bearings and rods,</span> and use semi fluid grease instead of oil for lubrication, not because I think it is better for wear, but because it is more viscous which should help dampen down ringing a bit, but this will only likely be visible after all the improvements I have already made, my main artifact now is the pulley teeth, and some ringing but that's it, no more improvements after this.</p><p>If you do go this far, put the slab on some sorbothane hemispheres to isolate any vibration from whatever you are using as your work table on which the printer stands, this wont help with the ringing, but will silence the vibration transferred into the table right down.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/ghosting-vfa-or-something-else/#post-195403</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/ghosting-vfa-or-something-else/#post-195391</link>
                        <pubDate>Tue, 25 Feb 2020 16:48:45 +0000</pubDate>
                        <description><![CDATA[Here is a bit of a debate going on about the merits of different lubricants. Tim is knowledgeable and his choice of lubrication is good, but could be better 😉 (But that&#039;s just my opinion - s...]]></description>
                        <content:encoded><![CDATA[<p>Here is a bit of a debate going on about the merits of different lubricants. Tim is knowledgeable and his choice of lubrication is good, but could be better 😉 (But that's just my opinion - sorry @Tim):</p><p><span style="background-color: #ffffff">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/can-i-use-these-lubricants-of-my-mk2-or-3/#post-170794</span></p><p> </p><p>But whatever you choose, like Tim stated, even car engine oil is better than nothing at all, the grease PRUSA supply is good, but you could definitely do with more to initially grease the bearings, this would then be followed up by occasionally lightly greasing the rods, no more than a thin film.</p><p>Also for info, after a few months, check your extruder cooler where the cooling fan is for gossamer filaments buildup which can eventually melt and drip onto your heater block as I found out. I'm going to get a can of compressed air or some sort of blower, and with a finger on the fan to stop it spinning, blow air back through the cooler to give it a clean out every so often.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/ghosting-vfa-or-something-else/#post-195391</guid>
