First print, very wispy then all over the place and doesnt stick
david.m122
(@david-m122)
I tried the benchy from the sd card. The printer first did little wisps before it started and then it started this. I canceled it at 3% when I say the print moving (not sticking). Any suggestions? https://imgur.com/a/UcxsK0q is a link to the image.
Thank you
Posted : 10/08/2018 3:37 am
Re: First print, very wispy then all over the place and doesnt stick
You need to adjust your 1st layer offset (Live-Z). I recommend following the process described here when starting out. Don't bother with more ambitious prints until you've got your Live-Z settings adjusted properly. Without proper adhesion, your prints won't be able to complete successfully.
Posted : 10/08/2018 4:52 am
