First layer inconsistent across build plate
luggw1
(@luggw1)
I've been printing on my MK3S+ with the MMU2s for a while now and am mostly quite satisfied with its performance.  However, as you can see from the attached photo, the first layer is rather inconsistent across the build plate.  This is a photo of a print near the end of the first layer.  If you look carefully, you'll notice the first layer is near perfect (in my opinion) in the lower right and upper left corners, but degrades steadly toward a band through the center of the build plate.
I placed a 12" combination square on edge on a glass work surface to verify its straightness and then placed it front to back and side to side on the build plate.  I found no issue side to side, but I did find the plate seems to fall away from the square by a few thousandths of an inch at the front of the plate.  However, that doesn't seem like it would explain the behavior I'm seeing.  Also, FWIW, this behavior didn't show up until after I installed the "+" upgrade to the MK3S and the MMU2S.  Is it possible the new bearing clamps are causing some deformation of the build plate?
Any suggestions for how to correct this issue would be greatly appreciated.
Thanks
Bill Lugg
Posted : 21/12/2021 9:46 pm
k1mu
 k1mu
(@k1mu)
RE: First layer inconsistent across build plate
How many Mesh Leveling points are you using? I'm using 7x7 which seems to compensate well for a not-entirely-flat build plate.
Posted : 31/12/2021 4:39 pm
luggw1
(@luggw1)
Posted by: @k1mu
Well, I've been using the factory default of 3 x 3.  I just posed this question to the Prusa Customer Support folks and they recommended this change, so I'm about to make it and see if I get better results.
Thanks
Bill Lugg
Posted : 31/12/2021 5:37 pm
