First layer creates wavy uneven lines
When creating the brim for my prints I regularly see the wariness as shown in the attached pic. It always occurs at the front right. The rest remains perfect. The first few lines a perfect and then it starts to happen. The wavyness persists into the actual print which is easily identifiable when inspecting the finished product.
What I've tried:
Full Recalibration
Cleaning the plate
Adjusting nozzle temp
Adjusting first layer z height
Thanks in advance for any help.
Re: First layer creates wavy uneven lines
[...] The wavyness persists into the actual print which is easily identifiable when inspecting the finished product.
If you have not already done so, try using Jeff Jordan's "Life Adjust" procedure for calibrating your Live-Z setting. It is much easier to use and understand than the on-board routine.
