Filament not going in, new printer
Cold_Taco
(@cold_taco)
Hello, I finished building my printer yesterday, but I can't get the filament in.
I'm preheating it to the PLA setting, but, when it tries to go in, it won't catch nor will it go through the extruder. I have attached a video of it along with a photo of the tip of the filament.
Any help is greatly appreciated!
This topic was modified před 5 years by Cold_Taco
Napsal : 23/05/2021 5:42 pm
RE: Filament not going in, new printer
You've set the tension screw way too tight.
Go back, read the assembly guide and handbook that came with the printer and try again ...
This post was modified před 5 years by --
Napsal : 23/05/2021 8:18 pm
Loosen this screw a few turns.
Napsal : 23/05/2021 8:46 pm
@cwbullet
More like a couple dozen turns - his video shows it clamped tight. But then Prusa ranks this part of the build as
Napsal : 23/05/2021 9:55 pm
Baklin
(@baklin)
Looks like you forgot the spring on that tension screw. Or you did install the spring and compressed it completely.
https://help.prusa3d.com/en/guide/5-e-axis-assembly_169235#170950
Napsal : 23/05/2021 10:06 pm
Cold_Taco
(@cold_taco)
@baklin
From everyone else's comments, it looks like I way overtightened the screw. However, even when i unscrewed it still didn't work, so i guess i'll have to take it apart and hope that i messed something up in there
Napsal : 24/05/2021 1:02 am
Both tightening the idler and leaving the spring out will result in failure.  We have all made mistakes.  Please let us know if you need more help.
Napsal : 24/05/2021 1:08 am
Lee W
(@lee-w)
Similar problem, except the printer will not even try to grab the filament.  Auto load is on but nothing happens.  This is a brand new printer.  disappointed to say the least!
Napsal : 24/05/2021 10:34 pm
Cold_Taco
(@cold_taco)
@lee-w
After fiddling around with mine for a while, i seem to be having the same issue as you. It heats up, and insert the filament, and i can see the gears turning, but no filament is moving. I'm not sure what else i can do except try and different filament perhaps
Napsal : 24/05/2021 11:24 pm
Dan Rogers
(@dan-rogers)
Spock:  It's fupped duck, Jim.
Napsal : 25/05/2021 1:07 am
Spock will solve it for these guys ...
Napsal : 25/05/2021 1:49 am
1 lidem se líbí
