Filament gets stuck during printing
Szabolcs Siebenhofer
(@szabolcs-siebenhofer)
Hello Guys!
I really need your help. This is my third attempt at a 30-hour print, but after a random amount of time, the filament gets stuck, and the printer finishes the job without printing anything. What should I check on the printer?
Printer: MK3S+, Filament: Prusa PETG, 2 different color and spool...
Thanks in advance!
Zibi
Napsal : 06/11/2024 7:08 pm
___MAX___
(@___max___)
RE: Filament gets stuck during printing
replace organic support with classic. small branches force frequent retraction and gear wears plastic. because of this it does not go further. another option: increase the retraction response distance, for example to 5 mm.
Napsal : 06/11/2024 7:24 pm
Thank you for the good advice; I succeeded. Next time, I need to consider not only the type of support I use but also its placement.
Napsal : 10/11/2024 10:12 am
1 lidem se líbí
