Failed x axis self-test
PYB
 PYB
(@pyb)
Hi all,
Apologies if this topic has been discussed numerous times but I'm kind of stuck here.
I built a MK3S bear with some official parts and some generic ones. When doing the self-test I have a failure for x-axis length I cannot solve. I tried the following so far:
- check belt tensioning & pulley alignment
- check cable management (I think I now know the assembly guide by heart!); movement is free on both sides of the rod
- grease the rod
What's disturbing is that I feel that there is more resistance (and noise) on the middle of the shaft - I may change the linear bearings to see if they are guilty but any other idea I might try?
Thanks!
Veröffentlicht : 19/07/2022 7:38 am
Mitglied
PYB
 PYB
(@pyb)
RE: Failed x axis self-test
That's what happens when you do not read instruction till the end *facepalm*
I did not see the step with a bear specific FW, will definitely try that. Thanks!
Veröffentlicht : 19/07/2022 10:22 am
Mitglied
No issues.  This happened to me too.
Posted by: @pyb
Veröffentlicht : 19/07/2022 10:30 am
PYB
 PYB
(@pyb)
So I tried with the bear firmware and it is not working 🙁 I also changed a bearing that seemed to be a bit broken.
What I don't understand is that the belt status is at 235 (so normally within range), and if I loosen it to approx. 260 then there is no tension at all. I'm starting to doubt about that measurement.
If anyone has other ideas I'm welcoming these!
Veröffentlicht : 19/07/2022 5:03 pm
PYB
 PYB
(@pyb)
Found it! And I need to post it in case other people as foolish as I am to build a MK3S from scratch have the same struggle.
The reason comes from the fact that I was using a 20 teeth GT2 pulley instead of a 16 teeth. That obviously changes everything!
Veröffentlicht : 19/07/2022 5:39 pm
That would be enough to break it! 🙂 lol...
are you using 16 tooth on Y axis?
Veröffentlicht : 19/07/2022 5:59 pm
PYB
 PYB
(@pyb)
That was the issue indeed, I was using a 20 teeth pulley 😞
For now I just took the 16 teeth one fr the Y axis, so I'll need to buy another one to complete
Diese r Beitrag wurde geändert Vor 3 years von PYB
Veröffentlicht : 19/07/2022 6:31 pm
Mitglied
That is also a problem.
Posted by: @pyb
Veröffentlicht : 20/07/2022 10:03 am
