Extruder Jammed
I was printing PLA and my i3 Mk3 got jammed. We've tried everything in the manual and almost completely taken apart the extruder. When we tried needles or acupuncture needles it would go in a mm and then get stuck and bend. Please help because I need to use the printer soon and it's been jammed for over a month.
Thanks
Posted : 21/03/2019 3:00 am
Re: Extruder Jammed
I have a metal rod about 1.6 mm wide. I heat up to 250/ open up the drive gear. then stick the rob down the filament path. after that clears it I run filament.
Posted : 21/03/2019 4:57 am
