					                		Crash Detection doesn&#039;t home - it homes to center and x/y axis coordinates are off - Assembly and first prints troubleshooting                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/crash-detection-doesnt-home-it-homes-to-center-and-x-y-axis-coordinates-are-off/</link>
                <lastBuildDate>Tue, 16 Jun 2026 03:31:00 +0000</lastBuildDate>
                        <title>RE: Crash Detection doesn&#039;t home - it homes to center and x/y axis coordinates are off</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/crash-detection-doesnt-home-it-homes-to-center-and-x-y-axis-coordinates-are-off/#post-185617</link>
                        <pubDate>Sat, 18 Jan 2020 00:10:54 +0000</pubDate>
                        <description><![CDATA[Don&#039;t use your polymer bearings until you have a reason to. Enjoy your printer now that it is working well.]]></description>
                        <content:encoded><![CDATA[<p>Don't use your polymer bearings until you have a reason to. Enjoy your printer now that it is working well.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>rmm200</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/crash-detection-doesnt-home-it-homes-to-center-and-x-y-axis-coordinates-are-off/#post-185617</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/crash-detection-doesnt-home-it-homes-to-center-and-x-y-axis-coordinates-are-off/#post-185612</link>
                        <pubDate>Fri, 17 Jan 2020 23:34:36 +0000</pubDate>
                        <description><![CDATA[@joantabbLOL you&#039;re probably right, should have lubed them anyway.@robert-rmm200I did loosen everything and found that the bearing, without it mounted, was still sticking. I lubed it and now...]]></description>
                        <content:encoded><![CDATA[<p>@joantabb</p><p>LOL you're probably right, should have lubed them anyway.</p><p>@robert-rmm200</p><p>I did loosen everything and found that the bearing, without it mounted, was still sticking. I lubed it and now it moves mores freely but still feel some slight resistance to it. I was able to get it to successfully print something but ordered replacement LM8UU Polymer bearings just in case.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>MotoGSXR</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/crash-detection-doesnt-home-it-homes-to-center-and-x-y-axis-coordinates-are-off/#post-185612</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/crash-detection-doesnt-home-it-homes-to-center-and-x-y-axis-coordinates-are-off/#post-185595</link>
                        <pubDate>Fri, 17 Jan 2020 21:27:14 +0000</pubDate>
                        <description><![CDATA[Very likely your three day old bearings are fine.If the bearing mount screws in the extruder are too tight - it will cause this. Loosen them a bit.And don&#039;t believe the instructions - and pr...]]></description>
                        <content:encoded><![CDATA[<p>Very likely your three day old bearings are fine.</p><p>If the bearing mount screws in the extruder are too tight - it will cause this. Loosen them a bit.</p><p>And don't believe the instructions - and probably don't use Prusa grease. Get a good bearing lube - and lube them properly.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/crash-detection-doesnt-home-it-homes-to-center-and-x-y-axis-coordinates-are-off/#post-185595</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/crash-detection-doesnt-home-it-homes-to-center-and-x-y-axis-coordinates-are-off/#post-185552</link>
                        <pubDate>Fri, 17 Jan 2020 18:13:22 +0000</pubDate>
                        <description><![CDATA[Ah well, you can use it now, as you are now doing maintenance...  ;-)Personally I have always Lubed from Day one.... I don&#039;t know why Prusa say not to lube...   it&#039;s a bit like expecting ass...]]></description>
                        <content:encoded><![CDATA[<p>Ah well, you can use it now, as you are now doing maintenance...  ;-)</p><p><br />Personally I have always Lubed from Day one.... </p><p>I don't know why Prusa say not to lube...   it's a bit like expecting assembly lube to protect your race car engine without additional lube...  </p><p> </p><p>regards Joan</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>JoanTabb</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/crash-detection-doesnt-home-it-homes-to-center-and-x-y-axis-coordinates-are-off/#post-185552</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/crash-detection-doesnt-home-it-homes-to-center-and-x-y-axis-coordinates-are-off/#post-185540</link>
                        <pubDate>Fri, 17 Jan 2020 17:17:48 +0000</pubDate>
                        <description><![CDATA[@joantabbNo, per the instructions the bearings didn&#039;t need to be lubricated as they were already lubricated and the included lubricant is intended for maintenance. I don&#039;t know if it is the ...]]></description>
                        <content:encoded><![CDATA[<p>@joantabb</p><p>No, per the instructions the bearings didn't need to be lubricated as they were already lubricated and the included lubricant is intended for maintenance. I don't know if it is the lube or if the bearing itself has failed somehow. I still need to take the bearing off the linear rod to take a look at the inside of the bearing.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/crash-detection-doesnt-home-it-homes-to-center-and-x-y-axis-coordinates-are-off/#post-185540</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/crash-detection-doesnt-home-it-homes-to-center-and-x-y-axis-coordinates-are-off/#post-185469</link>
                        <pubDate>Fri, 17 Jan 2020 10:23:35 +0000</pubDate>
                        <description><![CDATA[@dan-byundid you lubricate the bearings from new? regards Joan]]></description>
                        <content:encoded><![CDATA[<p>@dan-byun</p><p>did you lubricate the bearings from new?</p><p> </p><p>regards Joan</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/crash-detection-doesnt-home-it-homes-to-center-and-x-y-axis-coordinates-are-off/#post-185469</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/crash-detection-doesnt-home-it-homes-to-center-and-x-y-axis-coordinates-are-off/#post-185452</link>
                        <pubDate>Fri, 17 Jan 2020 08:47:53 +0000</pubDate>
                        <description><![CDATA[I tore the x-axis apart and found that the bottom bearing has some stiction when rolling side to side, guess it failed. Sigh...3 day old printer and more problems than my CR10S.]]></description>
                        <content:encoded><![CDATA[<p>I tore the x-axis apart and found that the bottom bearing has some stiction when rolling side to side, guess it failed. Sigh...3 day old printer and more problems than my CR10S.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/crash-detection-doesnt-home-it-homes-to-center-and-x-y-axis-coordinates-are-off/#post-185452</guid>
                        <title>Crash Detection doesn&#039;t home - it homes to center and x/y axis coordinates are off</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/crash-detection-doesnt-home-it-homes-to-center-and-x-y-axis-coordinates-are-off/#post-185446</link>
                        <pubDate>Fri, 17 Jan 2020 08:00:06 +0000</pubDate>
                        <description><![CDATA[I&#039;m seeing Crash Detection about 1hr into a 20hr print. I saw it occur and it actually didn&#039;t crash into anything, crash error shows it was on the x axis. When the crash detection error is s...]]></description>
                        <content:encoded><![CDATA[<p>I'm seeing Crash Detection about 1hr into a 20hr print. I saw it occur and it actually didn't crash into anything, crash error shows it was on the x axis. When the crash detection error is shown it doesn't home x/y to the front left corner, instead it homes to center and x/y axis coordinates are off. The print is then all shifted right. Has anyone else experienced this?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/crash-detection-doesnt-home-it-homes-to-center-and-x-y-axis-coordinates-are-off/#post-185446</guid>
