Confused on IR sensor MK3 to MK3S
FrankT
(@frankt)
A few months ago I upgraded my MK3 to an MK3S with MMU2S, following the guide. In this guide, and the kit I received, the filament sensor has a chimney and works like s sort of see-saw. This system does not work well. I have problems getting the sensor calibrated.
https://manual.prusa3d.com/Guide/3A.+MK3-MK2.5+-+extruder+upgrade/1069?lang=en
To my surprise, when I read the manual for upgrading just the MK3 to the MK3S, the sensor is completely different! It uses a ball. That's more like it. Did I miss something. What is the correct and best manual? I am confused.
Postato : 07/10/2019 7:47 pm
RE: Confused on IR sensor MK3 to MK3S
Hi Frank,
The tower sensor is the correct one for MMU2S/Mk3S
Postato : 07/10/2019 8:49 pm
Dave Avery
(@dave-avery)
mk3 to mk3s switches sensor from laser motion detection to IR+ ball
mk3 or mk3s mod to MMU2 switches to chimney and long arm tension door and moves the mk3s sensor to the chimney and removes the ball
the non-MMU setups use the sensor to enable autoload
the MMU setup uses the sensor to to tell the MMU the filament has engaged the extruder bondtech gears
Questo post è stato modificato 7 years fa da Dave Avery
Postato : 08/10/2019 2:00 pm
FrankT
(@frankt)
@david-a66
That makes sense, thanks.
Postato : 08/10/2019 8:01 pm
