Can't get past opening page
Loveny
(@loveny)
Edit: just confused about the button on the encoder vs the 'reset' button 😉
Just finished building the MK3 kit and powered up. All looks ok but as soon as I press the button on the panel the board resets and starts again with the opening message "Printer has not been calibrated". I've tried unplugging everything (apart from the power, obviously) and still the problem persists. What can I try?
Thanks,
Jon
Napsal : 26/06/2018 5:37 am
Re: Can't get past opening page
I am also confused!.
is this still an issue or have you overcome the initial set back?
Joan
Napsal : 26/06/2018 11:06 am
Marc_G
(@marc_g)
I'm assuming you're pressing the "x" button on the panel?
If so: that is the reset button, it is meant to reset the board.
You can navigate the menu by turning the dial and make menu selection by pushing the dial knob itself.
I hope that solves your problem and I didn't waste everyones time stating the obvious.
Napsal : 26/06/2018 1:01 pm
