Calibration failure after self test ok
Benik2
(@benik2)
Hi guys Just finished build my pursa mk3s+ kitAnd strange thing with calibration happened.
First thing I started with self test and everything works well but when I proceeded to xyz calibration it started well and when it arrived to the 4th point and finished it tries to move up Z only one side and stuck until restarting(can see in video).
Few notes I tried Z calibration and it fails (picture added)But it move smoothly and fails only when go back to the bed .
Other thing , when I move it all the way up manually with the knob it stops on 210 and not all the way up.
Any help or ideas will be appreciated
Opublikowany : 20/04/2022 3:00 pm
Benik2
(@benik2)
RE: Calibration failure after self test ok
IMG_4078
Opublikowany : 20/04/2022 3:18 pm
k1mu
 k1mu
(@k1mu)
When I assembled my mk3s, I plugged one of the Z axis motors into the wrong jack on the EINSY board. This caused what you describe - only one Z axis motor moving. It's worth checking out, as what I thought was the "logical" place for that was wrong, which meant that the Z motor and the extruder motor were reversed.
I hope this helps.
Opublikowany : 24/04/2022 12:27 am
