Bad Print
parallon
(@parallon)
Bad Print
Hello all,
I finally got my Mk3S+ going and on my first print, it came out crappy.  I did all the calibrations after setup including the Wizard.  I did the first layer calibration that I found on this site that prints about a 3" x 3" square to give you more time to adjust the Live Z.  I got it to what I thought looked good.  I think it was ~-1.055 or something like that.  Anyhow, this is how my first print came out using PLA.  On the top, you can see the 5 holes are totally ugly, and for some reason I got layer separation in the other photos, along with some weird bumps.  I used organic support (same material), which was buildplate only.  Can anyone explain the results and offer any recommendations?  I use a Ultimaker S7 at work, which is basically start and walk away, and I know the Prusa is capable of the same when set correctly, but I am at a loss.  How can some look good, and some look so bad?  FYI, all of this was sliced in the latest Prusa Slicer.  🙂
Thanks,
Nike
Opublikowany : 08/12/2024 3:15 am
parallon
(@parallon)
And here is the missing pic of the holes covered...  I couldn't get the first post to edit.
This post was modified 7 months temu by parallon
Opublikowany : 08/12/2024 3:49 am
