Anything I should be concerned about here? (overhangs and stuff)
[Résolu] Anything I should be concerned about here? (overhangs and stuff)
Page 3 / 3
Rick Lohr
(@rick-lohr)
RE: Anything I should be concerned about here? (overhangs and stuff)
Press the link to see it in action.  It allows the servos to be adjusted so that they put all three corners of the swash plate at the same height.  This is an old idea but apparently these are hard to come by for certain helis due to stuff being in the way so I made this one for a friend.
IMG_2042
Publié : 24/01/2022 8:49 pm
Swiss_Cheese
(@swiss_cheese)
Thanks for sharing your images, your parts are looking good, remember every model is different and the settings from the thread Sylvia sent you to aren't for every model, however the lessons learned there can be applied to many scenarios, example 0.39 extrusion width works great in some situations, however sometimes you might need to adjust a single perimeter to 0.55mm. The lesson was not to allow the perimeter layers to overlap to much, and to learn as you go the fine line between part strength and appearance. layer height plays into extrusion width as well. You will learn more as you print.
Enjoy
Swiss_Cheese
The Filament Whisperer
Publié : 25/01/2022 12:39 am
Rick Lohr a aimé
Rick Lohr
(@rick-lohr)
My first give back to the community.
Publié : 28/01/2022 12:10 pm
Rick Lohr
(@rick-lohr)
Filament Stand
Ce message a été modifié il y a 3 years par Rick Lohr
Publié : 28/01/2022 12:14 pm
Page 3 / 3
