2 year old i3 MK3S+ lost calibration this morning,
I have an i3 MK3S+ that I put together 2 years ago. Up until this morning it printed fine.
As of today I've had a succession of failures related to calibration, particularly X going past the right end of the build plate (user's right facing the front control panel of the unit)
I've taken the following steps
- Tightened screws related to the X & Z axis
- Tighten the screws holding the Y belt
- lubricated the Z & Y axis shafts
- Updated firmware from 3.9 something to 3.11.0
- Tightened the X axis belt tensioner
- moved the PINDA down to be the thickness of a zip-tie (1.1mm according to my
Along the way it once passed XYZ, I then worked on calibrating Live Z. The 2nd time adjusting live Z using a calibration file, it went all the way right (X) past the end of the build plate during pre-build bed leveling.
What should I be doing to get this working again?
What should I be looking for?
Best Answer by Diem:
Try a factory reset followed by updating the firmware and a first layer Z calibration.
Have you had any power glitches or thunderstorms recently?
RE: 2 year old i3 MK3S+ lost calibration this morning,
@Diem, thanks for writing.
No thunderstorms but we did have a short power outage recently. I've successfully printed after that though.
I recently started using an enclosure to address pealing at edges of longer prints. That has raised the ambient temp from about 16 C-19 C to ~30.5 C (87F), which seems to help with bed adhesion and eliminating warping off the built plate.
I'll take the steps above and report back.
Ed
Its now working
Left side below is the final after live z adjustment.
Working on next print.
https://www.printables.com/model/251587-stress-free-first-layer-calibration-in-less-than-5/files
Merry Christmas to all
Ed
