					                		Teplotni vyjimka a smrad z extruderu - Hardware, firmware a software (Pomoc)                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3-czech-cesky-hardware-firmware-a-software-pomoc/teplotni-vyjimka-a-smrad-z-extruderu/</link>
                <lastBuildDate>Mon, 13 Apr 2026 11:03:55 +0000</lastBuildDate>
                        <title>RE: Teplotni vyjimka a smrad z extruderu</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3-czech-cesky-hardware-firmware-a-software-pomoc/teplotni-vyjimka-a-smrad-z-extruderu/#post-779875</link>
                        <pubDate>Tue, 27 Jan 2026 11:55:32 +0000</pubDate>
                        <description><![CDATA[Tak nakoniec vyriesene vymenou termistora. Po nej sa este stale zjavovali teplotne vynimky, ale v ovela mensej miere. Po spraveni teplotnej kalibracie a PID kalibracie uz niesu ziadne chybov...]]></description>
                        <content:encoded><![CDATA[<p>Tak nakoniec vyriesene vymenou termistora. Po nej sa este stale zjavovali teplotne vynimky, ale v ovela mensej miere. Po spraveni teplotnej kalibracie a PID kalibracie uz niesu ziadne chybove hlasenia.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3-czech-cesky-hardware-firmware-a-software-pomoc/">Hardware, firmware a software (Pomoc)</category>                        <dc:creator>Peter</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3-czech-cesky-hardware-firmware-a-software-pomoc/teplotni-vyjimka-a-smrad-z-extruderu/#post-779875</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3-czech-cesky-hardware-firmware-a-software-pomoc/teplotni-vyjimka-a-smrad-z-extruderu/#post-777888</link>
                        <pubDate>Tue, 13 Jan 2026 08:26:31 +0000</pubDate>
                        <description><![CDATA[Ahoj,skontroloval som hotend, dal dolu oba fany. Na chladici hotendu, kam fuka bocny fan, bol prach, ale nic kritickeho. Vyfukal som vsetko stlacenym vzduchom. Na hotende (kovova kockava cas...]]></description>
                        <content:encoded><![CDATA[<p>Ahoj,</p><p>skontroloval som hotend, dal dolu oba fany. Na chladici hotendu, kam fuka bocny fan, bol prach, ale nic kritickeho. Vyfukal som vsetko stlacenym vzduchom. Na hotende (kovova kockava cast, kde je tryska) bola nasadena nejaka silikonova krytka, kt. ho obopina. Tu som tiez dal dole a vycistil. Uvolnil som a znova zatiahol utahovaciu skrutku, ktora je na okraji hotendu a ktorou sa utahuje vyhrevne teliesko. Netusim ako utiahnut termistor, okolo neho niesu ziadne skrutky a vyzera tam byt len tak vlozeny. Ale drzi tam pevne.</p><p>Potom som to otestoval a v poriadku vytlacil model, trvajuci 2 hodiny. Uz nic nesmrdelo, ziadne dalsie errory to nehlasilo. Mam podozrenie ze sa tam palil prach, zapach som najviac citil spoza bocneho ventilatora, chladiaceho hotend.</p><p>Dnes rano tlacim znova a pravdepodobne kvoli nenasadenej silikonovej ochrannej krytke hotendu som videl, ako pocas tlace teploty lietali. Nastavenych mam 218C pre prvu vrstvu, 215 pre dalsie. Teploty nahodne poskakovali 210-225, niekedy sa stabilne drzali na 218. Nakoniec po par minutach tlaciaren zobrazila teplotu ako 218/0 a opat skoncila s chybou "teplotni vyjimka" a neustalym pipanim. Pravdepodobre pre nestabilnu teplotu.</p><p>Tlaciaren som niekolko krat restartoval, nechal vychladnut na asi 130C na hotende. Nasadil som nazad tu silikonovu ochrannu krytku hotendu a skusil tlac znova. Pravdepodobne okrem ochrany hotendu od blobov prispieva k lepsiemu udrzovaniu teploty hotendu. Na zaciatku to este vyzeralo, ze teplota znova skace, aj ked v ovela mensej miere, mozno 1-2C hore-dole. Ale tlac sa nezastavila, len to par krat piplo a teplota sa momentalne stabilne drzi uz asi 30min, tlac pokracuje.</p><p>Tiez mam podozrenie na termistor, skusil som pohybat jeho kablikmi, ktore vedu okolo tlacovej hlavy dalej do "rukava" s inymi kablami. Kable vyzeraju navonok OK. Alebo ma termistor nejaky problem ked sa zahrieva, a ked sa uz zahreje, funguje dobre. Skusim ho eventualne vymenit.</p><p> </p><p>P.S. Vsimol som si, ze cely hotend (ta kockava kovova vec na kt. je tryska a v kt. je vyhrevne teliesko a termistor) sa da otacat okolo osky (skade vychadza filament z extrudera do trysky)...ma to tak byt? Nemalo by to byt viac utiahnute, aby sa to nehybalo? Ak sa to da dotiahnut, robi sa to pritiahnutim trysky? Pozeral som navod na skladanie MK3S a tam som nic nenasiel o nasadeni hotendu na extruder, tak netusim.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3-czech-cesky-hardware-firmware-a-software-pomoc/teplotni-vyjimka-a-smrad-z-extruderu/#post-777888</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3-czech-cesky-hardware-firmware-a-software-pomoc/teplotni-vyjimka-a-smrad-z-extruderu/#post-777853</link>
                        <pubDate>Mon, 12 Jan 2026 23:20:47 +0000</pubDate>
                        <description><![CDATA[Zdravím, pravděpodobně to bude smrt termistoru - zkontroloval bych jeho opatrné dotažení v hotendu. To co smrdí asi bude teflonová trubička, která končí téměř na úrovni heatbreaku. A pokud u...]]></description>
                        <content:encoded><![CDATA[<p>Zdravím, pravděpodobně to bude smrt termistoru - zkontroloval bych jeho opatrné dotažení v hotendu. To co smrdí asi bude teflonová trubička, která končí téměř na úrovni heatbreaku. A pokud umřel termistor a hotend topí tak ta trubička je to první co je na ráně (vydrží cca 265°C), než se začne tavit plast extruderu. Ještě se dá zkusit při nastavení teploty na 200°C šáhnout na chladič hotendu ze strany výstupu vzduchu jestli se nadměrně nazahřívá i při zapnutém ventilátoru. Pokud není k dispozici vysokoteplotní IR teploměr, nebo termistorové čidlo s multimetrem, tak ověření skutečné teploty hotendu bude obtížné. Ta teplotní ochrana funguje tak, že se kontroluje změna teploty a zároveň zda je zapnuté topení hotendu. Pokud je stále zapnuté a teplota přestane stoupat - tak dojde k alarmu a vypnutí ohřevu hotendu. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3-czech-cesky-hardware-firmware-a-software-pomoc/">Hardware, firmware a software (Pomoc)</category>                        <dc:creator>PaKo</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3-czech-cesky-hardware-firmware-a-software-pomoc/teplotni-vyjimka-a-smrad-z-extruderu/#post-777853</guid>
                        <title>Teplotni vyjimka a smrad z extruderu</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3-czech-cesky-hardware-firmware-a-software-pomoc/teplotni-vyjimka-a-smrad-z-extruderu/#post-777769</link>
                        <pubDate>Mon, 12 Jan 2026 09:09:17 +0000</pubDate>
                        <description><![CDATA[Caute, z tlaciarnou doteraz neboli ziadne problemy, az dnes. Dam tlacit z PLA, ma sa zahriat na 218C. Ked dojde na +- 200C, zacne neustale pipat a zahlasi &quot;teplotni vyjimka&quot;. Z extruderu je ...]]></description>
                        <content:encoded><![CDATA[<p>Caute, z tlaciarnou doteraz neboli ziadne problemy, az dnes. Dam tlacit z PLA, ma sa zahriat na 218C. Ked dojde na +- 200C, zacne neustale pipat a zahlasi "teplotni vyjimka". Z extruderu je citit smrad spaleniny a z trysky vychadzali "bafky" dymu, ako ked clovek fajci fajku.</p><p>Deje sa to aj pri manualnom nastaveni zahriatia, akonale idem cez 200C, uz hlasi problem. Vyskusal som aj napriek pipaniu vybrat a znova zalozit filament, co zbehlo OK, filament to vytlacalo z trysky v poriadku.</p><p>Ako som sa hral s tym zahrievanim, stalo sa tiez, ze cielova teplota spadla zrazu na nulu tj. bolo tam napr. 210/0 miesto 210/218.</p><p>Firmware mam 3.14.0</p><p>Skusil/skontroloval som:</p><p>- kalibraciu teploty, 2x zbehlo zahriatie cez 200C a opatovne schladenie, potom opat hlasilo chybu a pipanie. </p><p>- kable od hotendu a termistora a vyzeraju OK, nic tam nieje prepalene. Blob na tryske som tiez nemal.</p><p>Znepokojuje ma ten smrad spaleniny. Citit ho, len ked sa to ohreje na tych +-200C a viac. Akoby ten smrad siel niekde spoza ventilatorov, akoby z extrudera ci hotendu samotneho. Je mozne ze umrel termistor a smrdi on?</p><p>Dakujem za akekolvek rady/napady.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3-czech-cesky-hardware-firmware-a-software-pomoc/teplotni-vyjimka-a-smrad-z-extruderu/#post-777769</guid>
