					                		Nahodny problem s vytlacanim filamentu - Hardware, firmware a software (Pomoc)                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3-czech-cesky-hardware-firmware-a-software-pomoc/nahodny-problem-s-vytlacanim-filamentu/</link>
                <lastBuildDate>Sat, 16 May 2026 23:30:18 +0000</lastBuildDate>
                        <title>Nahodny problem s vytlacanim filamentu</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3-czech-cesky-hardware-firmware-a-software-pomoc/nahodny-problem-s-vytlacanim-filamentu/#post-779877</link>
                        <pubDate>Tue, 27 Jan 2026 12:01:19 +0000</pubDate>
                        <description><![CDATA[Ahojte, momentalne pouzivam filament Ender PLA. Teploty mam nastavene na 218 prva vrstva, 215 dalsie vrstvy. Problem sa vyskytol az teraz, ked uz filament dochadza. Akoby nahodne zatuhaval v...]]></description>
                        <content:encoded><![CDATA[<p>Ahojte, momentalne pouzivam filament Ender PLA. Teploty mam nastavene na 218 prva vrstva, 215 dalsie vrstvy. Problem sa vyskytol az teraz, ked uz filament dochadza. Akoby nahodne zatuhaval v tryske a tym padom ho mechanizmus nevie vytlacat von. Kolieska nad hotendom sa krutia ale "hrabu" a filament stoji, nejde dalej do hotendu. Ked dam hotend zahriat na 230-260, tenkou ihlickou prepichnem trysku, zacne filament vytekat. Potom pre istotu filament vyberiem, odstrihnem zubkovanu cast od koliesok posuvu filamentu a vlozim ho nazad. Potom uz posuv filamentu ide OK, ale po roznom case sa tento problem opat objavi. Ci uz v polovici tlace, alebo hned pri prvej vrstve.</p><p>Moze to byt nekvalitnym filamentom, alebo pouzit vyssie teploty pre PLA, napr. 218-220 pre celu tlac?</p><p>Dakujem.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3-czech-cesky-hardware-firmware-a-software-pomoc/">Hardware, firmware a software (Pomoc)</category>                        <dc:creator>Peter</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3-czech-cesky-hardware-firmware-a-software-pomoc/nahodny-problem-s-vytlacanim-filamentu/#post-779877</guid>
