Mk 3.9 with MK4 Z Axis motors.
Page 4 / 4
kermit
(@kermit-3)
RE: Mk 3.9 with MK4 Z Axis motors.
Yes, I know that, but for a long time both Z-axis engines were unavailable
Posted : 09/06/2024 3:34 pm
Steffen Hüttner
(@steffen-huttner)
Hi all, taking the risk of "reanimating a corpse" I am in a similar situation like the owner of this post but probably a little bit more advanced due to the fact that I have the MK3.9S. After reading the complete discussion I just want to make sure that I understand everything correctly.
If I want to move from the 3.9s to the 4s I need to replace the existing stepper motors for the x and y axis which are basically the same beside different cable length?
I can keep the motors of the Z axis as they are?
The reason why I ask is, when I check the Prusa website, it seams like they change the Z motors as well in the MK4s kit. Is this just because of the different connector?
Many thx in advance for your answer.
Greatings Steffen
This post was modified 12 months ago by Steffen Hüttner
Posted : 07/02/2025 8:51 am
3Delight
(@3delight)
Moderator Moderator
No, you will need the new z-motors and cables, etc. as they are different. From the 3.9S sales page:
Here is a closer explanation of the difference between the MK3.9 and MK4 upgrade packages: the only difference is in the stepper motors. The MK4 uses higher-precision stepper motors that help eliminate VFA (Vertical Fine Artifacts) – these are tiny surface artifacts that are visible if you closely inspect a printed object. In other words, the motors in the full MK4 upgrade are the cherry on top – if you’re chasing the highest possible level of quality, they will come in handy.
Posted : 07/02/2025 8:17 pm
Category 5
(@category-5)
The new Z motors differ only in their connector (you already have an adapter for the new board if you have 3.9s), but they are still 1.8 degree steppers so only the X and Y need to be changed.  They are the ones that have been updated to .9 degree.
Posted : 07/02/2025 8:20 pm
Steffen Hüttner
(@steffen-huttner)
Many thanks for the quick reply.
Posted : 08/02/2025 1:00 am
Page 4 / 4
