Issue after failed print
dehein2
(@dehein2)
Hi all,
I had a failed to print where a lot of material was stuck under the nozzle for a while, while is the printer was still printing. When I came back, I had a large pile of filament hanging under it. It also smells a bit but nothing too bad. 😉
After removing it, it still looks a bit bad, but I’m sure that’s not too bad for the print. Right?
While removing I noticed that the part at the bottom moves slightly around and it’s not completely tight dad I’m not sure if it was this way before. It’s supposed to be tight, correct?
thanks
Napsal : 23/06/2023 6:22 pm
Search for 'Blob of Doom' here and you will find all the related issues and remedies.
Napsal : 23/06/2023 11:04 pm
1 lidem se líbí
dehein2
(@dehein2)
RE: Issue after failed print
sorry, did not see your reply - Thanks!
Napsal : 04/07/2023 1:29 pm
