Error: There is an object with no extrusions in the first layer
Rob Muise
(@rob-muise)
Hi all, I am getting the above error when slicing my project.  I can seem to find the issue.  Any help would be greatly appreciated.
Here is the link to the 3MF file as well as the STL - Fence Hook-051023-3D-V1
Thanks
R
Opublikowany : 10/05/2023 4:55 pm
RE: Error: There is an object with no extrusions in the first layer
Please Try saving your project as a 'Project file' in Prusa Slicer,   (File, Save Project as)
then ZIP Compress the file, and then attach the Zip file, to your next post
you possibly need to use 'Fix with the Netfabb'. but short of seeing the project, that is a  total guess
Opublikowany : 10/05/2023 5:02 pm
Rob Muise
(@rob-muise)
Thank you, here is the project file.
Opublikowany : 10/05/2023 5:08 pm
Hi Rob,
My Guess, was correct,
The STL has errors
53 errors!  🙁
If you right click on the model in the man Prusa Slicer window
you should see
Fix through the NetFabb
Click that, and then try slicing,
You should get good results
Opublikowany : 10/05/2023 11:22 pm
