warp and crazy print quality on PLA
Warmage
(@warmage)
can some one help me with this print , and explain to me if this is overheating problem or what
the first 2 layers was ok , but it warped on the end of the print
Publié : 22/11/2017 2:57 pm
Re: warp and crazy print quality on PLA
Hi AbdulAziz,
this effect is indicative of poor Z level adjustment, the nozzle is too close to the build plate, in the corner where the surface is rough
try reducing the negative value of Live Z adjustment, if it's say, -.350 now, try perhaps -320, see if this helps,
effectively you are trying to squeeze too much filament into too small a space. which causes the surface to ruck up...
if this change helps but doesn't sure the issue, try again with Live Z -.300
Publié : 22/11/2017 3:44 pm
Warmage
(@warmage)
yes i just adjusted Live Z before this print , ill change it from -190 to -160 and give it a try
Thanks for the help and info
Publié : 22/11/2017 6:40 pm
Good luck!
Joan
Publié : 22/11/2017 7:33 pm
Sidbitters
(@sidbitters)
If your live z is set right and the mess was from the print lifting, then you need to get the print to stick better. Cleaning with acetone or at least 99% ipa should preveent this. On bigger prints, I have been using a brim.
Publié : 22/11/2017 8:08 pm
Warmage
(@warmage)
didnt help , if i change Live Z it will not stick to the bed and if i lower the Z by 10 it will be to close
and i still get the same effect , im confused as i printed the same file perfectly
i clean bed with IPA 70% , no access to higher IPA in my country
Publié : 25/11/2017 9:39 am
can you access pure acetone? not nail varnish remover (which has oils to protect fingers)
this can also clean your heat bed
Publié : 25/11/2017 10:56 am
Warmage
(@warmage)
no idea , ill ask the ladies and see if we have it here
Publié : 26/11/2017 7:05 pm
In the UK, Acetone is used in professional finger nail shops. To remove acrylic nails...
Regads Joan
Publié : 27/11/2017 10:56 am
BillC
(@billc)
Abdu,
Do not buy regular nail varnish remover. It has too many other ingredients. I have not found a source for pure acetone in Riyadh yet. Will post if and when I do.
cheers,
Bill
Tagaytay City, Philippines
Publié : 27/11/2017 4:10 pm
bnjmn83
(@bnjmn83)
To me something similar happened today. Not sure what it caused. The first layer and the rest seems ok but the top layer is just messed up. Never experienced this before. But I was thinking maybe of a temperature drift or something because those scars actually look like they popped out somehow after the print...
Publié : 27/11/2017 8:45 pm
Jose Ramon Diaz Ramos
(@jose-ramon-diaz-ramos)
Beware! I started with symptoms like yours and ended with a huge PLA tumor in the nozzle and a new V6 print head.
If you have checked first layer and is correct, extrusion is good, bed is clean with isopropyl/windex and or acetone and still have these issues, please, check the bolts and nuts that hold bed in place.
In my case I found that 2 of the 4 nuts were loose and although in the middle of the bed everything were acceptable, in the corners it was terrible with warping, ripples, baconing and the worse, severe lost of adhesion in general that made a part to come loose and sick to the nozzle ruining it.
Tell me if it works. I'm very interested in knowing if it is the same case than mine and if would have saved me from the plastic tumor.
Publié : 28/11/2017 2:09 pm
